AFTER firmware update phone starting and pattern incorrect issue 😩
(Topic created on: 09-30-2022 01:56 PM)
mengal009
Hello👋  I am using my Samsung galaxy s21 ultra mobile ( SM-G998B )  i don't have its cotton and I don't know its original CSC. And i rooted my phone   suddenly its black the screen and says  it will not reboot normally  so them i FLASH IS WITH EGYPT  CSC  SM-G998B  BUT after that  it's software status was official but  its not updating  it says that registration failed and after restarting  phone  .phone  starting  problem😩😩😩😩 and correct pattern gives many time such as 14000 minutes  to wait  plz any one solve it😮💨😮💨😮💨🙄
8 Comments
kakaayub
Manually update karo odin s
mengal009
Not fixed
mengal009
Not fix
DrShahid
Go near samsung center
mengal009
Yes he said that there are two software are punched on your phone🤔🤔🤔
DrShahid
It's like this when two windows installed in your pc
mengal009
Bro ya firmware B try kiya mei na kuch B nei howa Q
MhrHusnain
Re-flash the firmware again through odin and tick ✔️ auto reboot, nand erase, f. Rest time and then click on start. (Do make sure that you're flashing right firmware for your device)
