note 9 idle battery drain
(Topic created on: 08-17-2019 10:30 PM)
HamadHasan
Galaxy Note
Idle battery drain is a big problem in current Samsung smartphones..
13 Comments
usamaasif
Galaxy Note
idle battery drain means???
Galaxy Note
hahahah. phone jub waila para ho battery use ho to bhai isy idle bolty han.
usamaasif
Galaxy Note
thanks bro
usamaasif
Galaxy Note
plz guide me
HamadHasan
Galaxy Note
phone drains alot when i don't use it..
HamadHasan
Galaxy Note
my s7 edge had same problem... s10 plus has same problem also. exynos version have this issue
ZaryabAyub
Galaxy Note
i am also suffering from it , my battery doesnt even last for 4 hours of gaming .
Galaxy Note
bro I suggest u some tips go device care battery section and check which app use more in idle position. if none then turn off data and reset network setting
Galaxy Note
You Can Preserve Your Battery By Optimizing App From Device Mantenence It Will Improve Your Battery Life. You Need To put Apps on always sleeping mode. But Donot Put social apps like Facebook Whatsapp otherwise you will not get notification.
