🤔I think a cooling device works in note 20 ultra🤔
(Topic created on: 04-12-2021 11:17 PM)
Fahad100
Galaxy Note
When i use my phone its become normal according to room temperature but when 1 am stop using its become heated like something blow his heat outside...??
4 Comments
HasanAskari
Galaxy Note
Check if you put some important app on sleep. When you stop using the app tries to wake and system forced it to sleep. It consumes CPU and causes heat
Fahad100
Galaxy Note
Good reply. But when i use my phone it remains normal according to room temperature till 3 hours using i think note 20 ultra has cooling device in it..
HasanAskari
Galaxy Note
No man. There is some app that stops after screen goes off. It try again and again to restart but battery optimization stops it supposingly causing heating issue
HasanAskari
Galaxy Note
My battery stats are much better without using battery saving on. I lost one hour battery rather then saving it while the battery saver and sleeping apps is on.
