Resolved! Solved
Edge Panel Problem....
(Topic created on: 06-10-2021 09:38 AM)
Hiruka_NU
Galaxy M
මගේ Device එකේ edge panel එක open කරනකොට හිරවෙවී open වෙන්නෙ.තව කාටහරි මේ ප්‍රශ්නෙ තියේද🤔🤔?ඒක හිරවීමක් නැතිව smoothly open කරගන්න මොනාද කරන්න ඕනෙ සහ බලපාන්නෙ🤔🤔???
Screenprotector එකේ ප්‍රශ්නයක් කියන්න නම් බැහැ .Notification panel එක Full screen gestures එහෙම කිසිම ප්‍ර්ශ්නයක් නැතිව smoothly වෙනවා.මේක විතරයි අවුල🤔🤔෴?
(M11)
ඇත්තටම කිව්වොත්කිසිම animation එකක් නැතුව එකපාරට open වෙන්නෙ👇👇👇👇👇👇👇👇
Dineth_Hesara
Galaxy M
Yes there is an issue in some/every devices at some/every time you use edge panel due to its unstability in almost unstable/beta oneui versions....this cant be fixed with either optimisation of ram management or increasing the animation time through developer options.
Only one fix i have been able to find so far also for my devices....reducing the apps in shortcuts....
Happy to know if anyone found any other fix.. 😁
9 Comments
Dineth_Hesara
Galaxy M
Hiruka_NU
Galaxy M
Thanks for your answer and it didnt work.I think samsung fix this problem in future updates
Dineth_Hesara
Galaxy M
Yes they must...many users have already reported....wish i could help more but...mine sometimes fixed using less apps in shortcuts....its not there to force stop in the app manager too right??
1meth
Galaxy M
Wallpaper link?
Hiruka_NU
Galaxy M
Here is the link and paste to browser and download from google drive☺️..👇👇👇👇👇👇👇👇👇👇👇👇👇👇
https://drive.google.com/file/d/1ThYtZBhS9Z3dSHSwrCdliIIgZeRHV1lB/view?usp=drivesdk
1meth
Galaxy M
It's not working ? Asking for access
1meth
Galaxy M
Hiruka_NU
Galaxy M
sorry for the problem.I have forgot to change settings☺️❤️❤️now okey
RaviJa711
Galaxy M
Hadagaththane
