kindly please Fix my problem ? Model A20s Please Help
(Topic created on: 04-24-2024 07:57 AM)
Usman_Zargar
9 Comments
Saifikhokhar
software ki update check kro agr update honay wala hy to kr lo sai hojaye ga
Usman_Zargar
Ni bhi ma ny sab check kia par ni ho rha isi wjha sy phone khud ba khud off ho jta ha
Saifikhokhar
to phir Bhai YouTube kro
UmarFarooq7
If you've backed up your data.. try resetting your device
AliHasanZaidi
back up kar lo main aap ko official firmware deta hoon A20S KA CSC KONSI COUNTRY KA HAI PAKISTAN YA KOI AUR COUNTRY KA INSHALLAH AAP KO KOI PROBLEM NAHIN HOGI
Usman_Zargar
G bhi pakistan
Usman_Zargar
CSC?
AliHasanZaidi
https://samfw.com/firmware/SM-A207F/PAK/A207FXXS5CWF1
How to flash Samsung Galaxy A20s SM-A207F firmware
1. Extract (unzip) the Samsung firmware file. Recommended using WinRAR or 7-Zip
2. Download Odin Tool 3.13.1
3. Extract Odin ZIP file
4. Open Odin execute file
5. Reboot Samsung phone in Download Mode (hold Home + Power + Volume Down buttons / hold Volume Down + Bixby buttons then plug-in cable)
6. Connect you Samsung phone and wait until you get a blue sign in Odin
7. Add the 1 file Samsung firmware to AP/PDA or 4 files Samsung firmware (AP/BL/CP/CSC) to it's slots
8. Make sure re-partition is NOT ticked
9. Click the START button, sit back and wait few minutes
