Samsung A51 Battery issue any solution
(Topic created on: 09-14-2023 09:42 PM)
Vicky345
10 Comments
Viky bhai a51 ka softwere aya koi apke mobile mein
Vicky345
No
Ok
aakashnawab7
If battery backup is normal, then keep using and ignore this message.
If you're facing poor battery backup and charging problems, then go for battery replacement.
This message is showing that your battery's health is poor.
Vicky345
Battery 🔋 timing normal but showing weak battery
aakashnawab7
Then keep using it. This error message will get removed automatically after few days.
Vicky345
😊 Thanks
aakashnawab7
Welcome
san24x
Mera bhi same yahi issue a rha ha.. Apna battery change krwai ha ya thek hogya
