Heating and battery draining problem
(Topic created on: 06-15-2023 01:37 AM)
ĄĐŇĂŇĶHĂŅ
My samsung phone A52s 5g
My phone is overheating after the last update and the battery is draining quickly
7 Comments
aakashnawab7
Mine is heating a little bit, battery life is Okay.
But fast charging speed is slower now. I have replaced the charger and cable but still charging is slow
Taking 2.02 hours to charge from 0% to 100%
Is anyone facing this issue ?
Can anyone quote his/her charging time also ?
itx_mughal
bhai grmi ki waja say charge slow ho jati hai. . phone aisi jaga charg kro jaha temperature normal ho or charge krte wqt back cover remove kr diya kro. .
aakashnawab7
Brother AC k samne bhi check kia h. Last update k baad waqai charge slow ho rha h cell. Screen ON ho to 5 Watt se uper nhi jaata.
Screen off ho to 10 watt se uper nhi jaata. Chahe mobile off ho, ya on.
(15 watt charger)
25 watt charger pr 16,17 watt se uper nhi jaata, chahe kuch bhi krein.
1 nhi 3 alag chargers se check kia h. Or sb Samsung UI 5.1 pr ho rha h aesa. A51 pr bhi, A52s pr bhi.
aakashnawab7
Battery time bilkul theek hai. Backup waghaira 100% Okay hai.
A51 pr February patch hai, usme heating nhi ho rhi bilkul bhi.
May patch A52s mei heat ho rha h mobile. Baghair use k bhi.
Reset bhi kr lia
Ab better hai, lekin Thora Thora heat ab bhi hai.
hussain_2020
Beginner Level 4
Go and sell your phone fast as you can
ahmad344
Sir go to settings apps and salact usb setting clear deta and checha this issu fix
GalaxyA73x5G
May update ma charging slow hn gai hai or battery draining b pehla sa hn rahi same mera saath b yehi issue aa raha mera pass A73 hai
