Battery life decreasing problem.
(Topic created on: 11-19-2023 08:40 PM)
Ismail04
Community Guidelines
How to remove Acton required in Battery status
7 Comments
Ismail04
This is the problem. Anyone's who knows the solution. Screenshot_20231120_093303_Samsung Members.jpg
HasanAskari
Your battery is about to die.
You have only 2 options;
1)Complete 0 to 100 charge and discharge cycles for atleast 3 times.
If it doesn't work
2) replace the battery, but before replacing the battery perform a soft reset. Chances are low but it might help
Ismail04
Battery working is fine, but on the diagnostic test, show that Battery life is bad.I don't know what happened to him.
HasanAskari
Ok it means some calibration issues.
Don't do anything. Next time when your battery is about 5% power off your phone and charge till 100.
See if it works
Ismail04
OK thanks Bro.
I will do it and see the result.
SAHASamsung
Beginner Level 3
How much time your battery is covering? 10 hrs or 12... with normal use. No gaming and on battery saver mode
Karman1
Battery ziyada use krny waly Apps khatam kro
