Pro Mode for Pro's
(Topic created on: 04-02-2022 09:00 PM)
ShenalDe
Tech Expert
How often you use the Pro mode to capture stunning images..
Pro mode let's you choose all the image balance you need to capture a perfect moments
Then come the result of what you have captured from Pro mode..
I know its not the best since the leaf was shaking and too much of wind.. its to give you an idea of how you can capture images like a Pro
8 Comments
Tech Expert
Of course bro. Pro mode is superb if you know what to do.😁
Tech Expert
Yes bro definitely 🙌
Tech Expert
Yeah.. one of the best feature ❤❤
Tech Expert
Of course buddy ❤️
Tech Expert
A very underutilized feature. Its probably because people don't know the advantage of using Pro mode plus it takes some level of skill
Tech Expert
True bro I have been using Pro Mode from S10plus to s22ultra so it's the best way of capturing a clean photo
Tech Expert
Amazing feature👍
Tech Expert
Yes bro indeed 😍
