Resolved! Solved
Power button delay
(Topic created on: 08-14-2022 02:02 AM)
Not applicable
Tech Expert
When I press my device's power button to turn on when it loocked
It takes up to 5sec to show lock screen. What can I do for this. Need your help.!
2 Solutions
SARJUNMF
Tech Expert
Tech Expert
Hi there!
What's your device? Also are u using a 3rd party lockscreen? Are u using powersaving mode or some apps that could be forcing your device into deep sleep?
Let me know. I don't recommend using 3rd party apps to clear cache though
5 Comments
Sha_zan
Tech Expert
I suggest you to factory reset your Galaxy Device. Make sure to have a backup file before resetting.
Be sure to click the 3 dots and " ✓ Accept as Solution" when you find an answer that works for you.
Thanks... 👍
SARJUNMF
Tech Expert
Clean your Cache memory
It can help you.
Try https://play.google.com/store/apps/details?id=com.piriform.ccleaner
Tech Expert
Hi there!
Not applicable
Tech Expert
I did clean cache
Now it's fine ❤
Tech Expert
Glad it worked!
