Resolved! Solved
Need help
(Topic created on: 09-02-2024 11:15 PM)
Heshn
Tech Expert
After the recent 6.1 update, I have noticed a delay when opening the camera app on my S22U The camera lens takes a while to open. Could you please provide some solutions to address this issue?
Tech Expert
You could try a simple data clear of the camera and see if there is any change at all.
If my comment helped you in any way, please consider hitting the 3 dot menu and accepting it as a solution. It helps me. Thank you!
Tech Expert
