04-25-2025 08:51 PM (Last edited 04-25-2025 08:52 PM ) in
Tech Expert
If your Galaxy Drains more battery than usual or if there any micro stutters, try the following :
1. Wipe Cache Partition ( if not helps use 2nd method )
2. Backup the data and factory reset or if you have knowledge of flashing the correct firmware using Odin use that method.
Hope the battery drain and Micro stutters are fixed after the steps. I personally tried 1st one Micro stutters are fixed but battery drain not fixed. So used 2nd method and things are working perfectly 🤗
If you have any methods or if you used same methods mentioned above please comment😇 it will be helpful for other samsung members.
10 Comments
- « Previous
- 1
- 2
- Next »
04-29-2025 08:15 PM in
Tech Expert
Good to hear🔥
- « Previous
- 1
- 2
- Next »
