How to Fix Abnormal Battery Drain & Micro Stutters after Oneui 7
(Topic created on: 04-25-2025 08:51 PM)
Tech Expert
If your Galaxy Drains more battery than usual or if there any micro stutters, try the following :
1. Wipe Cache Partition ( if not helps use 2nd method )
2. Backup the data and factory reset or if you have knowledge of flashing the correct firmware using Odin use that method.
Hope the battery drain and Micro stutters are fixed after the steps. I personally tried 1st one Micro stutters are fixed but battery drain not fixed. So used 2nd method and things are working perfectly 🤗
If you have any methods or if you used same methods mentioned above please comment😇 it will be helpful for other samsung members.
10 Comments
Tech Expert
Helpful post❤
Tech Expert
Janith842
Tech Expert
Great ❤🔥
Tech Expert
Tech Expert
Icon pack ...😊
Tech Expert
Tech Expert
Tech Expert
RISKYTAP
Tech Expert
This is a helpful post; I haven't experienced any issues with my S24 Ultra since the update. So far so good
