Resolved! Solved
Finger print recognize problem
(Topic created on: 10-15-2022 08:50 PM)
Thanusan
Tech Expert
My friend finger print work my phone I don't add
Tech Expert
First, remove the fingerprint. Then add the fingerprint again. As Dihane said, there may be a problem with the tempered glass
If my answer was helpful, please click the 3 dots on the right and accept the solution.
Thank You
7 Comments
Tech Expert
What type of finger print sensor is it please tell I can find solution for you
Thanusan
Tech Expert
Indisplay
Thanusan
Tech Expert
In display
Dihane_M
Tech Expert
First remove the finger print and add it again. If you can't add it it might be because you're using a tempered glass.
If you're not using a tempered glass and still can't add kindly contact Samsung (it might be a bug)
If my answer was helpful please click the 3 dots on the right and click accept solution 🙂 😊
Tech Expert
Thank You
mahzal
Tech Expert
1. Check if your finger has any liquid or dirt
2. Clean the fingerprint module
3. Check if the fingerprint module is well connected
4. Restart your device
5. Update your software
6. Wipe system cache
7. Recalibrate the fingerprint
8. Reset your device
9. Visit the service center
Tech Expert
Hi... your device is S10 series?
