Hasith88
06-15-2020 09:55 AM in
Others
4 Comments
Wish22
06-15-2020 08:51 PM in
Others
disable it
ShyamRankothge
06-15-2020 10:17 PM in
Others
Do not disable Google services. Instead there are tutorials in YouTube where you can minimize the battery usage. Check them. I'll try to post the link to a video
Hasith88
06-19-2020 07:36 AM in
Others
thanks👍
OshanMadusanka
06-16-2020 07:07 AM in
Others
What are the consequences which can happen after disable it? Cause I also disabled it. Otherwise battery consumption is too high.
