yaseerstark
05-28-2025 11:18 AM in
76 percentage for 3h 43 minutes battery drain so fast even in power saving mode on there aren't any battery issues
2 Comments
YurajM
Beginner Level 3
05-28-2025 06:07 PM in
Same here brother.
Janith842
05-28-2025 10:11 PM in
Most users are experiencing this after the One Ui 7 update. Even the midrange and Flagship devices. Samsung will fix these battery draining issues with the next security patches they release for the devices. Until then we need to wait. Since you have enabled all power saving options no need to do anything. Just restart your phone once.
If my comment helped you in any way. Please consider hitting the 3 dot menu of my comment and accept it as a solution. It would be helpful for me a lot.
Thank you 😊
Thank you 😊
