Display No Best colours and no work always on display properly πŸ˜•
(Topic created on: 04-03-2023 11:58 AM)
Raisa_01
Please check this 😭
10 Comments
Hi can you please describe your problem properly? You can change display settings by going to Settings >> Display >> Screen mode
You can activate Always On Display by going to Settings >> Lockscreen >> Always on Display.
If my comment helped you in any way, please consider hitting the 3 dot menu and accepting my answer as a solution.
Thanks 😊😊
Raisa_01
Maybe u have a theme installed? Ur picture isn't clear at all
Raisa_01
First 4to take a screenshot shot in my phone second one photo by other phone
Hi... can you tell more about the issue? Is it happened recently? And what's your device model? πŸ™„
Raisa_01
Raisa_01
vashek03
Sometimes the always on display switches off when you have your battery saver on!
Raisa_01
