Can we block touch while using camera ? I need to work camera with only buttons
(Topic created on: 01-29-2022 08:12 AM)
cptNAVA
Touch block while using camera
6 Comments
GAJAN_Rajasek
Hey bro,
It's very easy...
Open camera
Tab to settings
Find shot method
Open it and change your wishes...
Or normally, open camera and press volume key, now it's taking shots
Thank u.
If you find any help with my answer, click on 3 dots and click on "Accept solution
Hi there, you can't block touches. But u can use the buttons to shoot. If your device supports a bluetooth spen like the s21 ultra, you could snap pics using the spen. Hope this helps 😊
Whats the device you are using?
snowrisesback
Go on Samsung tips app and check camera tips bro
I think you can't do it without third party applications 😃👍
