Call Recording Issues on Galaxy S23 FE Running One UI 6.1
(Topic created on: 10-27-2024 12:21 AM)
Lakshitha222
Hi everyone,
I'm having trouble with call recording on my Galaxy S23 FE, which is fully updated and running One UI 6.1. I've tried almost every call recording app on the Play Store and Galaxy Store, including Cube ACR and several others. All of them appear to operate as expected, but when I check the recordings, the audio is distorted and unusable. I've set up all necessary permissions and connectors without success. After reaching out to the ACR app developer, they mentioned that this issue might be specific to the Galaxy S23 FE, possibly due to software restrictions on the device that prevent third-party apps from recording audio correctly. Has anyone else experienced this issue or found a workaround? I’ve attached a sample recording to illustrate the problem. Any insights or advice would be greatly appreciated. Thank you!
