VeNoM_ac
09-09-2023 11:22 AM in
Does anyone know a good place (in Colombo)to buy galaxy 21 battery? Please let me know.
Solved! Go to Solution.
3 Solutions
Shavi_S_
09-09-2023 09:18 PM in
09-10-2023 04:09 AM in
Hi.. If you are looking for a battery replacement, A Samsung service center would be the best place. But prices might be a little higher than normal shop. You can check on a regular shop as well. But make sure to choose a reputed one. Liberty Plaza is the ideal place to choose.
09-10-2023 10:43 PM in
There are a few relaiable places in Liberty Plaza such as Genius Mobile, My Fix it and Western Mobile.
But a samsung service center would be best.
If my comment helped you in any way, please consider hitting the 3 dot menu and accepting my answer as a solution.
Thanks 😊😊
Thanks 😊😊
4 Comments
rayan56
Beginner Level 3
09-09-2023 08:44 PM in
Me too looking
Shavi_S_
Barclay's in MC..
Thanks 😊😊
Thanks 😊😊
