Resolved! Solved
Note 9 Battery Replacement
(Topic created on: 06-18-2024 05:03 AM)
zeyidhnote9
Galaxy Note
Hi
Has anyone replaced the Samsung note 9 battery? Is it worth it ? Please share your experience 🙏
3 Solutions
Galaxy Note
If you chose authorized Samsung service center for replacement, the price will be slightly high. But you'll get the assurance of genuine battery and probably a warranty period. So if you're going with 3rd party shops, make sure to select a reputed repair shop 😊
Galaxy Note
Hi Western Mobile in Libery Plaza and Myfixit Libery Plaza are both trusted and reputed.
Western Mobile let's you watch while they remove and replace the battery. I had an issue with them, though, where the camera got stuck after the battery change. They got down a different battery, and it worked perfectly, and I got a 6 month warranty as well. Hope this helps!
If my comment helped you in any way, please consider hitting the 3 dot menu and accepting it as a solution. It helps me. Thank you!
Galaxy Note
10K but this was about 1 year ago
9 Comments
Galaxy Note
zeyidhnote9
Galaxy Note
Any authorized service centres you know?
Galaxy Note
zeyidhnote9
Galaxy Note
How much did u replace it for? Also does the heating issues get solved with the new battery?
Galaxy Note
zeyidhnote9
Galaxy Note
One more thing is the heating issues solved with the replacement?
Galaxy Note
Which heating issue are u talking about ?
zeyidhnote9
Galaxy Note
The phone usually gets a lot hot while charging also gets hot while doing a little heavy task
Galaxy Note
I think it's not a battery issue, but the processor is being pressured to work harder to keep up with modern apps and stuff. Battery heating during charging can't be stopped
