Display/Battery swap on Note10+
(Topic created on: 08-18-2024 09:47 PM)
Chinthy1
Galaxy Note
My device recently got green lines in the middle of the screen, and my battery drains ridiculously fast! I was looking to fix or swap my display as well as get my battery swapped, but Idk where to go...
Is there any reputed place that I could take my device to get it fixed? Also around how much would it cost for the display and battery respectively?
Thanks in advance for your help!
2 Comments
Galaxy Note
I can't tell u the exact price for the display. Maybe 80K, the battery will cost about 10K or so. There is a place at Liberty Plaza called Western Mobile. They do a pretty good job. Another place called MyFix, which is also pretty good. Both at Liberty Plaza. Make sure you call before u go.
If my comment helped you in any way, please consider hitting the 3 dot menu and accepting it as a solution. It helps me. Thank you!
Galaxy Note
The display is so expensive 😫. Around 70k-80k. Battery is also around 8k to 12k. There are lots of shops at the Liberty Plaza. I know a place called "Smart phonez repair" they has genuine products at low prices. They are doing their job very well. We can also watch the repairing process.
If my comment is helpful to you in any way, consider to select the Accept Solution by clicking on the 3 dots of the comment.
Thank you ☺️
