Resolved! Solved
Problem with power saving mode
(Topic created on: 02-08-2023 07:07 PM)
Mohamed_Dilshath
Galaxy M
I turn on power saving mode to use phone continuously. I try to switch off and it is switched off. But it's still working . How to fix
Sha_zan
Galaxy M
According to me, there may be some sort of error in the update released on your Galaxy device. It will likely be solved by future security patch updates.
11 Comments
RISKYTAP
Galaxy M
Have you checked with the settings according to your error?, have u tried to restart ur phone or Optimise it..
Galaxy M
Yeah I tried but still it is working
RISKYTAP
Galaxy M
2 opinions You Can connect it to ur PC then Store ur all data in it and do backups
Then go for a factory reset
Or
GO FOR A Customer service center
Galaxy M
I reset but still it is working
RISKYTAP
Galaxy M
No mate not reset it called factory reset. U will get ur device just like the day u bought it "Search how to factory rest samsung device on YouTube.
Galaxy M
I am also telling factory reset formatting the phone fully
RISKYTAP
Galaxy M
yes but when u do have back ups u lose nothing.
Galaxy M
1 week ago
RISKYTAP
Galaxy M
is it still bugged?
