Battery Drain Problem
(Topic created on: 09-08-2021 07:28 AM)
CLAdhikarinayake
Galaxy M
මගෙ Samsung M11 එකේ හැමදාම රෑට use කරන්නැතිව තියල උදේ නැවත ගන්නකොට Battery එක 10-20% අතර ප්‍රමාණයක් බැහැල තියෙනවා,ඒ හැටිද නැත්නම් අවුලක් ද
Please Tell me
15 Comments
Liyoshiyona
Galaxy M
it's a normal brother. This will definitely happen if you are in a low signal area,
Sometimes the battery capacity is low if the applications you are using is running in the background. Turn on the flight mode of your phone overnight and see if there is a change in battery capacity
Not applicable
Galaxy M
Just asking, you said you were German, didn't you? Can you speak Sinhala? Are you a Sri Lankan living in Germany? Or an heir of German blood by birth?
Liyoshiyona
Galaxy M
I am German by birth and I am currently studying my higher education at a university in Sri Lanka where I learn to speak and write Sinhala.A Sri Lankan friend of mine translates things into Sinhala in the Samsung Members app.
I can speak and write some things in Sinhala at the moment අම්මා, අයුබොවන්, ඔයා, පන්සල්, ඉස්කූල, සපට්ටුව, බොඩිම, etc. I can read and write words like this
Shehant98
Galaxy M
Battery එක 1-8% ක් වගේ ප්‍රමාණයක් අඩු වෙන එකනම් normal(background processing). 10-20% ක වගේ battery draining එකක් වෙනවනම් මොනවහරි apps or services background run වීම නිසා ලොකු battery draining එකක් වෙන්නෙ. ඒක නිසා මොන apps, services ද overnight battery consumption වැඩි කියල බලලා ඒ apps වල background process disable කරලා බලන්න.
Galaxy M
Aiye 10%තමා හැමදාම වගෙ අඩු වෙන්නෙ,හැබැයි power saving mode දාලා තියෙන්නෙ,ඒක අවුලක් නැද්ද,normal ද
Shehant98
Galaxy M
10% normal. ඔයා රෑට mobile data, wifi off කරනවනේද. On එකේ තියෙනවනම් ඒත් baterry reduce වෙනවා වැඩිපුර. රෑට background run වෙන apps services check කරල බැලුවනම් හරි.
Galaxy M
Even 10% is ok. If its reducing more, you might have to check your phone.
My phone reduces sometimes 15% if i leave wifi or mobile data on in the night, if not its usually 5% and thats normal.
Rata mokak hari background eke wada karanawada balanna.
Hiruka_NU
Galaxy M
එහෙම තමා ඉතින් මං power off කරල තිබ්බත් 5% ,6% ක් බහිනවා🤣
Galaxy M
Ohh no!!😎🤔
