Low coverage problem...🥺
(Topic created on: 07-23-2022 11:30 AM)
SMJ5PRO
Galaxy J
How to fix this problem?
7 Comments
Galaxy J
Hi 👋
Try these steps
1. Restart your device
2. Reset network settings
3. Try to use another ISP (Change the sim)
4. Reset your device
5. If any step didn't fix that issue so that means it's a hardware issue, so i think you can use device with wifi connection or if you need to fix it just go to the nearest samsung costumer services centre 🙂
So if my comment is useful to you, use the 3 dots in my comment for accept my comment as a solution. 😉 👍
Galaxy J
Hey,
Do not waste your time answering this person. Check which answers are always accepted. It is always from one person. So we all know what that is. 🤭
Galaxy J
I noted that ayya, 😄 i did it for a double check😅 thank you so much ayya❤✌
Galaxy J
Hi... If there are no hardware or software issues on your device, as users we can do only limited things on that. Simply go to a high ground to get coverage or use another service provider which has good coverage in your area. Try this app below to check the signal status in your area.
If my comment is helpful to you in any way, consider to select the Accept Solution by clicking on the 3 dots of the comment.
Thank you 😊Screenshot_20220724-003313_Google Play Store_148745_1658602994.jpg
Galaxy J
Hey mcn,
Galaxy J
Ohh yes... 😄 just noticed. Thanks ❤️
Galaxy J
So desperate for solutions?
