Resolved! Solved
Sound Assistant problem
(Topic created on: 08-15-2025 09:14 AM)
DIHarshana
I can't find the Samsung sound assistant app on my A26. Does anyone have a solution? 🫩
Goodlock modules are officially not working on Galaxy A26. You can use finelock to get the Sound Assistant app. Below the link
https://play.google.com/store/apps/details?id=yuh.yuh.finelock
If this comment helped you in any way please consider hitting the 3dot menu and accept as a solution 🙏
