AkashMadusanka
01-23-2025 07:39 AM in
After 5 years my galaxy a30s suddenly stopped working. I was using hotspots from it and it turned off. And It's not charging.
Any helps guys ?
7 Comments
Vister
01-23-2025 07:42 AM in
There's a greater chance for the battery connecters to get disconnected or an error of the battery.
Sometimes, it may be a main board issue. So, consider giving it to a shop and check the error.😊
01-23-2025 08:17 AM in
Try plugging into power, holding onto the power and volume down key for 20 secs. It might force a reboot. Please give me an update
AkashMadusanka
01-23-2025 08:43 AM in
Sure.. I'll
AkashMadusanka
01-24-2025 11:14 PM in
Hey, it didn't work. The technician said it was a NAND flash failure.
01-24-2025 11:43 PM in
That's sad ... anyway hope u got it sorted
Janith842
01-23-2025 10:40 AM in
I also have an A50 Bro. The same thing happened. As Sadesh said, I plugged to the charger and pressed and hold the power button and volume down keys. But it didn't work. Once shown to a repair shop they told to replace battery. They checked with a high voltage charger, too, but it didn't work.
After doing these steps, if your phone doesn't work. Go to a repair shop and see, bro. They will check and let you know what's the issue with it.
AkashMadusanka
01-23-2025 10:41 AM in
Thanks for the info
