Fix Battery Drain issue After Android 12 Update.
(Topic created on: 02-16-2022 10:07 PM)
If anyone Facing Battery Drain issue after android 12 Update on any Samsung Device Do this Tutorial.
I Got Battery Drain issue After i Updated My A52s 5G.
And i Fixed using This methods.
1.Charge Device to 100 And Go to Dial pad And Dial *#0228# And Click Quick Start and press ok.
2. Dial *#9900# And Select Battery Stat reset.
3.Switch of phone and Reboot on Recovery mode and click Clear cache Data after Click repair Apps.
After i Did all This My Battery Drain issue Fixed if anyone need try This methods..
My Battery Useage After done All this.
#Android 12
#Fixed
#Battery
#issues
14 Comments
If its Worked perfectly for you then Accept it as solution.
우다리
Thanks for sharing
Shawkey
The first code *#0228# doesn't work, Do you have alternatives?
They removed that after update
