Battery Drain and Charging issue
(Topic created on: 09-05-2020 12:20 AM)
Amharthajudeen
Hello, I been using my A50 for almost an year now, had replaced the charging port once at the service centre around last November. Sometimes the battery Drains faster like even with light usage but sometimes it's ok... but not the best.
I even have issues with the charging bcs sometimes it says charging and stops charging after few seconds and I have to plug and replug after few times before it charges, and also if sometimes if I try to turn on my phone it shows the battery charging indicator before I try again to turn it on. Anyone facing the same above problems with there A50 pls let me know. Tnx ❤
5 Comments
MiyuruG
ya it looks like your battery gives more endurance time compared too mine, 5hours on 27% and mine gives like 3 hours at 20%. tnx for the info brother ❤
MiyuruG
Yeah it is.. You are most welcome brother.
Menuka1
Try to reset your phone....
Try calibrating battery. Try resetting. If it doesn't work contact a customer service centre.
