04-19-2025 01:31 PM in
جالاكسى SSolved! Go to Solution.
04-19-2025 05:52 PM in
جالاكسى SYou're welcome. The side button must be replaced.
I'm pretty sure about the camera not being connected properly with the main board, as this is not the first case. I've seen a lot of users, and after visiting the Samsung Center, they've been informed about that.
Note that slapping / dropping the phone harder can cause the camera failed warning as I watched that on drop test on YouTube.
In some cases, wipe cache and data of the camera app might solve the issue other cases might not.
04-19-2025 01:50 PM in
جالاكسى S- Mark as New
04-19-2025 01:57 PM in
04-19-2025 02:45 PM (Last edited 04-19-2025 02:46 PM ) in
جالاكسى SCamera failed warning means the lenses aren't connected properly with the motherboard. Put your phone into maintenance mode and visit the nearest Samsung service center to resolve the hardware issue.
04-19-2025 03:14 PM in
جالاكسى SDo you think this could mean the internal connections, like the camera to the motherboard, are loose or misaligned? Since both cameras aren’t working, I’m guessing it might be something similar?
04-20-2025 08:54 AM in
جالاكسى SAs long as I can use the portrait lens (even though it’s zoomed in a bit), I can manage for now. I’ll definitely keep your advice in mind and plan for a service center visit when it’s more convenient.
Appreciate your time and the solid explanation!👏
04-20-2025 04:34 PM in
جالاكسى SYou're the most welcome. Thanks for your kind words 🌹
