S21 Gap issue between display and frame
(Topic created on: 02-01-2021 10:03 PM)
ManSixTwo
Hi did anyone notice gap between display and frame for s21 on top left and right corners,  I can easily place a paper between frame and display is that normal ... ?
Could you guys check and let me !!
17 Comments
Shrini23
Nice info..
Wonder, even my S21 Ultra has an air gap..u r right..
Now in doubt, will the splash proof work..
i need to query with customer care in this regards..
Thsnk u
ManSixTwo
seems that gap is normal , air gap is for front speaker.. frame is designed like that... and screen is properly sealed..
kpundir
Thats for earpiece and speaker sound. However , they should have provided some mesh or grill instead of just keeping it open
Shrini23
Yes..u may be right..
as there is no extra groove or (mesh kind) for top speaker as like earlier models..
Anyhow i put up a query at support team.. will revert if i get any response.
GEEHITH
please contact service team
satyanand7
.I bought an s21 last week... there are gaps between the display and the frame.... i ordered replacement then the replaced one also came with the more gaps replay as soon as possible what should i have to doo now
ManSixTwo
it is normal for s21 series
satyanand7
ip68*???
ManSixTwo
metal case is designed like that ip68 is there ..
