08-04-2024 12:11 AM (Last edited 08-04-2024 12:13 AM ) in
جالاكسى S- Mark as New
08-04-2024 02:36 PM in
جالاكسى SOr-update your phone
Or factory reset
08-07-2024 02:40 AM in
جالاكسى SGood Evening
1- Make sure to close applications in the background, and also turn off Wi-Fi when you stop using it, and reduce the lighting.
2- Optimize the battery through Settings, then Battery, Device Care, then Optimize Now
3- Please make sure that the device is up to date by going to Settings, then Software Update, then Download and Install
4- Activate battery protection through settings, battery, device care, battery, then more battery settings, then battery protection.
5-Activate energy saving
6- Go to Settings, choose Battery, then choose Background usage limits, then choose to put unused applications in sleep mode
and please run a test via Samsung members app> go to Support -> Diagnostics>then battery
if the test result is action required unfortunately in this case you need to visit Samsung service center
have a great day, and stay safe
