Battery drain s24 ultra
(Topic created on: 02-03-2024 09:15 PM)
guzplace
جالاكسى S
The issue as per attahed screenshot
Gallery stories app I am not able to stop
And download manager please advise
4 Comments
dmcROCK
جالاكسى S
I have the same thing the battery drain fast.
Samsung_Expert
جالاكسى S
You can find out which applications are draining your battery by going to Settings, then Device Care, then Battery.
You can enable power saving mode when you need saving mode
You can also put unused applications into sleep mode by going to Settings - Device Care - Battery - clicking on 3 dots - clicking on Sleep applications - and adding the applications you want.
Christinaa
جالاكسى S
Hello, Battery Is draining fast. The google play service is using 39% of the battery. But I dnt know what to do and how to fix it, it went from 57% to 39% in less than 30 mns.
Christinaa
جالاكسى S
Same here
