M51 connection problem
(Topic created on: 01-15-2021 08:26 PM)
TechGeek18
جالاكسى J
M51 When using headphones connected via Bluetooth while using Wi-Fi such that "Wi-Fi & Bluetooth " are active. The internet speed is incredibly slow that it stops any viritual meetings and conference. Without valid reason I try several types of Bluetooth earphones exact the same thing !!!!
 Kindly fix this issue because it is so bothering. Thanks in advance.
2 Solutions
Not applicable
جالاكسى J
This is a kind of a wireless interference .
Both Wi-Fi and Bluetooth use the 2.4 GHz band to transmit data, and because of this Bluetooth audio skips or cut the connection .
It is a common problem unless for devices which support the 5 GHz band for the Wi-Fi for example .
Check your's
Not applicable
جالاكسى J
I think your device support the 5GHz band , what about the router , in order to avoid this interference .
2 Comments
Not applicable
جالاكسى J
Check your's
Not applicable
جالاكسى J
