hi I have problem with my note 10 plus
(Topic created on: 10-02-2020 10:40 AM)
Not applicable
جالاكسى نوت
note 10 plus volume decreases all by itself when I play any music the volume go down without i do anything when go next music the volume go up again i dont know whats wrong if someone had the same problem or solution
Miatham
جالاكسى نوت
7 Comments
Ownz
جالاكسى نوت
make sure smart volume is turned off .
Not applicable
جالاكسى نوت
where I can find the smart volume
Ownz
جالاكسى نوت
in samsung music app
Miatham
جالاكسى نوت
Not applicable
جالاكسى نوت
but the problem with sound clouds if i play music there
Miatham
جالاكسى نوت
Try to go SoundCloud- settings - basic settings - click clear application cache
Ownz
جالاكسى نوت
I dont use sound cloud, so...
maybe there's an option in sound cloud that's causing the problem
