Note FE Battery not durable
(Topic created on: 04-01-2018 10:49 PM)
Maqsood1
Beginner Level 3
جالاكسى نوت
my new Note FE battery really not durable as i expect. its finished within 5-6hrs even not continue used. is there option to make battery life better...plz advs
4 Comments
bohemia1
جالاكسى نوت
you might be having lots of bacground running apps on your mobile data
Maqsood1
Beginner Level 3
جالاكسى نوت
thanks i will check and tell u again..
جالاكسى نوت
https://youtu.be/p33axErhGuQ here is the answer
vezir
جالاكسى نوت
note fe icin android 8 ne zaman geliyor
