battery drain quickly S8+
(Topic created on: 01-09-2018 08:28 AM)
Danish1986
اخرى
after update my battery drain quickly S8+ even power saving mode on
14 Comments
Fries
اخرى
Can you try to boot it to safe mode?
Danish1986
اخرى
how to boot in to safe mode?
Danish1986
اخرى
i found it how to boot safe mood but what i have to do in safe mode
sk8
اخرى
hi
David4
اخرى
everyone is facing same problem.
May be it'll be fixed in next update
rizvi2
اخرى
same happend to me as well Samsung plz fix it swiftly
اخرى
Hi. am not facing this issue because i always check the apps that works in background
Danish1986
اخرى
same here but still draing if you video call then battery drain quickly
SalmanMahi
اخرى
yes I Am facing Same problem
