Wall / desk mount for Samsung Odyssey G7 monitor
(Topic created on: 04-25-2023 05:56 PM)
MrLight54
اخرى
Does anybody know where I can find a compatible wall / desk mount? It's taking too much disk space and I want to mount it.
3 Comments
Amira-elnagar
اخرى
MrLight54
Hello. I’m Amira, Samsung Moderator
Thank you for asking the question
We wish you a happy day
Based on your inquiry regarding the update
We ask you to explain the problem you are facing in more detail to be able to help
If you have any other question, can you explain it to us
We are  at your service always
Thanks for your time
MrLight54
اخرى
Hi Amira. It's not related to any updates. My Samsung Odyssey G7 monitor is taking too much desk space, so, I want to mount it on the wall. The monitor came with a 100×100 mm VESA mount (photo attached). I don't think it shoud be screwed into the wall directly, but I'm not sure. From what I've seen online, I should attach it to a compatible wall mount or desk mount. However, I can't find any compatible mounts. Can you please confirm if I should screw this part which I have directly into the wall. If that's not how it works, then where can I find a compatible wall mount, please?20230426_211142_1000013894_1682536304.jpg
Amira-elnagar
اخرى
MrLight54
Based on your question
We ask your permission to contact us through the hotline 16580, and work again from 10 am to 4 pm
And after breakfast from 9 pm to 11 pm all days of the week
Or through the WhatsApp number 01000016580
