11-16-2023 02:20 PM in
اخرى
11-17-2023 04:05 PM in
اخرىDrsal
Hello. I’m Mehad , Samsung Moderator
Thank you for asking the question
We wish you a happy day
Based on your inquiry regarding the update
Check if the phone has dropped or exposed to water
Try another Wi-Fi connection
Dial *#2663#
Tap Refresh Wi-Fi version
If you are still facing the same issue we recommend that you perform a factory data reset to resolve this issue using the steps below:-
Launch the Settings app and tap General management → Reset → Factory data reset →
RESET → DELETE ALL.
Ensure all user data is backed up using smart switch
from the link below and then use the backup tool to create a data backup
http://www.samsung.com/eg/support/smartswitch/
If you’re still facing the same issue, kindly take the device to the service center to check on it.
you can follow the link below to find the nearest one :
http://www.samsung.com/eg/support/servicelocation/
If you have any other question, can you explain it to us
We are at your service always
