Problem connecting Samsung ear puds 2 pro with Galaxy S 22 Ultra
(Topic created on: 03-12-2024 02:44 PM)
ossmashal
جالاكسى S
I have an issue while i am trying to connect Samsung ear buds 2 pro with my Galaxy S 22 Ultra, when i open thr wear App, it will discover the Buds but when i select them it will stay loading and not go to the next screen
Note: the buds is already connected to my phone using the bluetooth and working fine with the phone.
Does anyone have a solution for this or at lease why this is happenning!!!
3 Comments
Samsung_Expert
جالاكسى S
Please follow the below:
You can start by uninstalling the Galaxy wearable app from the phone
then you can do a factory reset for the watch
Perform a reset from the watch's settings
Navigate to Settings.
Swipe to and tap General.
Swipe and tap Reset.
Tap the checkmark and follow any on-screen instructions to start the reset.
After that, you can reconnect the watch with the phone using the Galaxy wearable app
and check for the update in the watch please
ossmashal
جالاكسى S
Thank you for the message, but my issue is with Galaxy Buds not Galaxy watch!!!
ossmashal
جالاكسى S
I knew th problem its the ear buds not working with wear app
