V2srivi46
12-29-2019 06:16 PM in
Tips
First of all reset Ur phone
and uninstall all Unused samsung apps and disable bixby......
go to powermode and select medium power saving mode
and de select the limit cpu speed to 70% and set screen resolution as hd+
select put apps to sleep when imediately it's not in use
this will improve ur battery performance and keep charging between 20 to 90%
it will give battery improvement
Try and give ur valuable comments.......🙃🙃🙃
5 Comments
DhruvS20FE5G
12-29-2019 07:29 PM in
Tips
why we bought flagship phone if this is to be done for battery management. samsung has to look into it.
PANKS1
12-29-2019 07:38 PM in
Tips
lol...better to switch off the phone in this case and save battery for ever....why the hell we spend 30-40k on phones to restrict everything...
Kartik271994
12-29-2019 07:47 PM in
Tips
Do you think Apple has a very good battery backup 🤣🤣
TOMVV
01-02-2020 11:36 PM in
Tips
Having Super AMOLED display and restricting it to HD+ that is too sad, for rest of the points 👍👍
PurshuRana
01-17-2020 11:56 AM in
Tips
guys dont blame this guy...if you like it follow otherwise leave....he suggested to do so in emergency situations..
