Problem with mobile data switching from both of simcards and problem with wifi
(Topic created on: 11-08-2023 03:09 PM)
ErPiyushGupta
Tips
Hi Team Samsung,
After upgrading to third beta update
Problem with mobile data:
In mobile data, When switch 1st sim to 2nd sim & 2nd sim to 1st sim, so in that case mobile data not working also no symbol show like 5g ,4g,4g+ network on network notification area..
In that case I did switch off my mobile, restart my mobile, Apply then rrmove airplane mode, remove then reinstated simcard card tray, but none of them work...
When I did this for seven to eight times then the network bands name showing..but this should not be happened
Problem with wifi connection:
Sometimes wifi connection is not connected also it automatically disconnected
Please check this issue and immediately release a patch...
6 Comments
IndiaBetaTeam
Tips
Dear Samsung member,
Kindly share logs just at the time of the issue occurring as without logs issue cannot be analyzed this issue. Please share the complete issue description, please share video/image, logs, and report issues just at the time of occurring with the video.
To attach the log file:- Samsung member > Click on beta banner > Switch to beta mode > Beta feedback > Send feedback > Error report. This will help us to further investigate and resolve your concern.
India Beta Team
jyani29
Beginner Level 5
Tips
I also face same problem
Yanao
Beginner Level 3
Tips
Guess we have to wait for next update lol. 😭😭😭🤣
ErPiyushGupta
Tips
Already sent
firstofgalaxy
Tips
Yes, network issue after 3rd beta update
ErPiyushGupta
Tips
The only solution for problem 1 as of now is---
If you want to use mobile data in both Sims one to another, so suppose you are using mobile data on sim 1 and you want to use sim 2 mobile data so in this case you select sim 2 as a mobile data sim and then you have to restart your mobile phone ...and after restart you are now able to use mobile data on sim 2 ...and this same case to be applied when you switch back to sim2 to sim1 ....
but this thing(restart mobile)is very bad...
Samsung should immediately give a resolution patch..that we don't require restart mobile again and again
But after upgrade VoIP is completely disappeared
