I am facing auto re-start,shutdown problem frequently in my galaxy m21 ,pls sugg
(Topic created on: 11-30-2021 11:40 AM)
Bapi2000
Tech Talk
4 Comments
SaiLorRahul
Tech Talk
Try reinstalling software from service centre
Bapi2000
Tech Talk
After Software installed from service center the problem same
SrajTech
Tech Talk
https://youtu.be/5z-3Nc3a1Rk
Watch this video and send mail as instructed
Raise it on twitter
cs-member13
Expert Level 4
Tech Talk
Dear Samsung member,
Thank you for sharing your concern. And please follow the easy troubleshooting steps which might help to solve the issue.
Kindly use a genuine Samsung charger.
Note: We always recommend using a genuine Samsung charger for charging your device.
There are two methods to disable the auto-restart function
Method 1
Please follow the below steps:
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on General management.
Step3: Tap on Reset.
Step4: Disable Auto restart (if enabled).
Step5: Auto-restart disabled.
Step1: Go to "Settings"
Step2: Tap on "Battery and device care"
Step3: Tap on Three dots
Step4: Tap on "Automation"
Step5: Disable "Auto-restart at set times" if enabled
Warm regard,
