Battery drain
(Topic created on: 09-23-2022 03:38 PM)
Not applicable
Questions
Battery drain problem in s21 after update one ui 5.
2 Comments
IndiaBetaTeam
Questions
Dear Samsung Member,
Greetings from India Beta Team!
We acknowledge your feedback.
However, we request you to please report this feedback in the Error section, along with the logs. This would help us analyze your issue in a better way.
The path to report error is as below:
Open Samsung Members -> Click on beta banner -> Switch to beta mode-> Beta feedback -> Send feedback -> Error report
In the meanwhile, To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Thank you for being our valued customer.
India Beta Team
djprem
Questions
Clear cache via recovery ; it will fix the drain issue after 2 charge cycle or 48hrs.
P.S : you may notice huge battery drain post clearing cache : it normal will get fixed after 48hrs or 2cycle.
