Issues After 2nd Beta Update
(Topic created on: 04-15-2025 09:26 PM)
Ishaan_A55
Discussions
After updating to second BETA I noticed :
1. After unlocking the phone there is major fps drops.
2. The touch response feels slow ( even though using 120hz feels jittery)
3. 5g speed has gone down.
4. There was a nice zoom out effect while opening the phone in lock screen which is gone.
5. STILL FINDING MORE ISSUES.
(Another issue why there are no views on every beta community post ??)
Issues that are not fixed 😒:
1. The animated clock style still doesn't work.
2. VoLTE doesn't show in status bar.
3. The charging animation in Nowbar dissappear within 3-4 seconds.
4. Transition from AOD to lock screen is not as shown in good lock.
5. I Nowbar it still sometimes says stopwatch or timer instead of actual numbers.
10 Comments
SquareLabs
Discussions
The point you gave after updating 2nd beta was faced with me also. However when i restarted my device its working absolutely fine and smooth than 1st beta with no issues
So please consider restarting your device
1.Clock is not still updated and it doesnot work now also
2.when though VoLTE is not showing ins status bar but its still on .To check it just swipe down to see controls and now it show up.
Extra i want add that it your are in 4g network areas it catches 4g instead of 4g+
3.Restart device would be recommended
4.Midrange smartphone of samsung i don’t expect it would add seamless AOD
Ishaan_A55
Discussions
About that VoLTE that's my point it should show directly without swiping down quick panel. And about seamless AOD I don't know that Samsung will do. And I have restarted my phone.
Thanks for your information 😊
KhanShab473
Discussions
Yes its right
timkamat
Discussions
As for VoLTE in status bar, it is not the bug, but intentional feature. One UI 7 will have only network symbols along with type (like 5g, 4g), wifi , battery, time and now bar. Samsung says it is to declutter the status bar
Ishaan_A55
Discussions
Okay 👍
siddiq2142
Discussions
Dont you have any battery drain issues.Cuz I'm facing alot
Ishaan_A55
Discussions
Yes I'm facing that to but I didn't mentioned it bcz BETA version always takes more battery
siddiq2142
Discussions
Is there any chance for getting back normal after stable version
Ishaan_A55
Discussions
Yes absolutely
