Enabling Light Battery Mode on Beta
(Topic created on: 09-16-2022 11:18 PM)
LuciferMorningstarr
Discussions
So apparently there is a way to enable light mode of Z fold 4 in S Series on OneUI 5 beta. The 'device care' in battery still shows optmised mode after enabling this. We could check the battery performance after enabling this and report back here.
with Adb:
Light mode:
adb shell settings put global sem_low_heat_mode 1
Default mode:
adb shell settings put global sem_low_heat_mode 0
Discussions
Yes the value could be 1/True but does it actually apply to S series is something we need to check. I did a quick check on the CPU cores and didn't see any drop when it's 1.
The backup should increase at least by some hours under similar usage.
SRIRAM2022
Discussions
Yes it's not working as of now , need to see next 2 days , I will update from my end, but I saw in youtube that with the mode it's reduce performance of 8plusgen1 to 8 gen 1 to get more battery life. Now ours was 8 gen 1 so no improvement so far , but will check 2 days
S_Kumar73
Discussions
The performance profile not showing in my S22 ultra
SRIRAM2022
Discussions
Why ? Under batter , more battery settings u can see the profile option,
S_Kumar73
Discussions
No it's not thereScreenshot_20220917_195602_Device care_1000011090_1663424769.jpg
SRIRAM2022
Discussions
Processing speed is that option dude
S_Kumar73
Discussions
In that only optimised, high and maximum only there. Which is already there in previous version as well. No light mode or standard mode.SmartSelect_20220917_222042_Device care_1000011111_1663433443.jpg
SRIRAM2022
Discussions
That's not available at present, with adb mode we are checking that works are not please read the thread completely
S_Kumar73
Discussions
Yes I read that.
Discussions
Over a day of moderate usage, still 35% left. Mostly on 4G only. Can't seem to infer whether it is actually working or Placebo. Will have to test for a few more days Screenshot_20220918_121651_Device care.jpg
