Heat issue
(Topic created on: 04-16-2024 02:04 PM)
Sunilkumar454749
S24 ultra to much heat using time
4 Comments
Mayur000
Summer effect.
Use AC room, also switch on AC while using phone.
If you have no Ac, only deshi, then don't use phone day time, use battery saver mode, wait for cool time or night.
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
Turn off Wi-Fi, GPS, Bluetooth, etc: Turn off unused functions like Wi-Fi, GPS, Bluetooth & Location settings when not using them.
Please follow the below steps:
Step 1: On the home screen swipe down the notification panel.
Step 2: Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Decrease the screen brightness: If your device is heating, decrease the screen brightness sometimes high brightness level may cause the heating issue.
Is there any unnecessary application running in the background?
Kindly close the background running applications in the device (Tap the left side key & close the background running application).
Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications: Settings> Apps> Select the third-party application from Apps> Uninstall.
Long duration of graphics-intensive gaming sessions may cause the heating issue.
Usage of mobile phones when charging may cause heating issues. So we recommend you avoid usage of mobile phone while charging.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
