02-22-2024 06:38 PM in
Galaxy S- Mark as New
02-22-2024 06:57 PM in
02-22-2024 08:23 PM in
02-23-2024 08:33 AM in
Galaxy SDear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Smart Dual SIM enables a call waiting on both SIM cards. It even enables the call forwarding on both numbers. So, if one of the numbers is out of reach, the incoming calls will be forwarded to other numbers.
Path: Settings> Connections> SIM card manager> Smart dual SIM> OK on Pop up> Enter Phone numbers and tap on OK> Select SIM card and tap on Done.
In case the issue still occurs. please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
02-23-2024 08:38 AM in
