Battery draining so fast on my S22 ultra
(Topic created on: 02-17-2024 02:56 PM)
SaajidR6
My phone battery draining so fast even using on battery saver and extra dim display. I charge my phone on slow charging mode taking 2 hours to charge.
I charge only below 20 percentage to full charge at once
4 Comments
vinayshah
Check which app is using more battery, disable that app & see if that makes any difference. Also, u can try safe mode to see how much the battery lasts.
Kuldipindia
Battery backup is superb in S22 plus.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issues by given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device charging issue: https://www.samsung.com/in/support/mobile-devices/issues-with-wired-charging/
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
JithinAjith
Settings 》Google 》Devices 》Turn off scan for nearby devices
Settings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
Settings 》Location 》Improve Accuracy 》Turn off Bluetooth and WiFi scanning
