Battery Replacement for S10 5G
(Topic created on: 11-08-2023 06:57 PM)
Ravindu_Deshan
Where can I find an original replacement battery for Galaxy S10 5G? (SM-G977N)
I contacted the samsung and they asked me 30,000 LKR which costs 1/4 of the price of this phone I bought😪.
A phone repair shop from Maharagama asked me 12,500 LKR for an OEM battery.
What should I do?
7 Comments
I don't wanna play 30k
I'll find a well phone repir shop for the replacement
But they should sell ෆේk batteries as well. That's why I'm caring about this too much 🥲 I'm also not living near colombo, So if they sold a Faක් battery, කට්ට කන්න වෙනවා ආයෙම 🥲
If the 12,500 LKR battery has 4500mAh the buy that battery because it can handle the same duration as you original battery I suggest you to buy the 12,500 LKR one.
Yeah, thank you ❤️
You have to think of cost vs functionality. Since your phone has gotten old, its probably better not to spend a ton of money on it. Rather save that money for a new phone some day. So yes the 12,500 option seems better. Make sure everything works normally before you leave after the replacement. I had an issue with my camera and they had to change the battery again to fix it
lethusha
How can you check original or **bleep**?
Dhana38
Battery replace kalada ??? Battery gaththa shop eka mokakda ???
